Hi I need an android phone for some important apps that are not on Windows phone but since I used Nokia 920 I need something that is fast and with no lags or hangs.
What can you suggest.
Hello Moto .... choose between the E, G & X depending on your budget.
But seriously, why did u not post this thread on android central....for i thought the android section here was only for the Nokia Android series.
