SP3: Replace broken power supply through laptop power supply
  • Thread starter WPCentral Question
  • Start date
WPCentral Question
Hello,
unfortunately my power supply of my new sp3 is broken. I already ordered a new one, but it will take some
time until the new power supply will be there. I really would like to use my sp3, so I have been thinking about replacing the broken power supply by another one. From my old asus netbook I have a power supply with 12V and 3.0 A output.
Is it possible to use this one for loading?
I have been searching in different forums about the replacement of a power supply, I always read, that an egual voltage is necessary and that the amperage can be higher, the device should handle the correct amperage.
What do you think about this?
Thanks!
Poirots Progeny
499
The sp3 has a proprietary connector. Unless you're willing to take the risk of fire and damage, the only way you'll get it working is by splicing the cables. I do not recommend you do this at all.
kuyhaa
