How do I connect an Epson XP-410 printer to my Surface Pro 3 using wifi?
  • Start date
How do I connect an Epson XP-410 printer to my Surface Pro 3 using WIFI
My printer and my Surface Pro are not connecting
jmshub
Moderator
Apr 16, 2011
2,667
Re: How do I connect an Epson XP-410 printer to my Surface Pro 3 using WIFI
The XP-410 will work on WiFi. Do you have the printer paired successfully to your wireless access point? If not, on the printer's interface, find WiFi setup. Start the setup wizard, choose your WiFi's name from list of available networks, and press the enter key. You'll need to enter your password, and you should have your printer on your network.
Then to add the printer to your Surface, you install the printer like you would on any other Windows PC. Go to epson.com and find the drivers for the XP-410 ( Epson XP-410, Drivers & Downloads - Technical Support - Epson America, Inc. ). Download and run the Drivers and Utilities Combo Package. That will install the drivers packages and software utilities for the printer.
jmshub
Moderator
Apr 16, 2011
2,667
I just bought that same printer for my grandmother about two weeks ago. I am not an oracle of infinite knowledge, I just set it up recently enough that I remembered the model number!
jacobss
