Surface Pro 4
Any idea when information will start being released on the SPro4? All the rumors so far come from copy/paste sites and untrustworthy. I have the original but skipped out on the 2nd and 3rd one because they weren't enough of a performance boost to justify a purchase. I'm pretty excited about the SPro4, but the only way I'll consider it is if they provide a much better GPU for 3D work and a better quality digitizer with more than 256 levels of pressure. I'm sure the CPU will get a boost since they will probably use a Broadwell chip. I don't need a higher resolution. That just cuts into performance.
Re: Surface Pro 4
If you frequent this site and pay attention to the articles I'm sure the minute anyone knows of credible information you'll find it here.
Assume anything else to be simply rumour.
