Draining the battery while on charge. Is it possible?
systematicchaos
63
I have been using L535 for months but now all of a sudden it doesn't charge. It shows the charging icon but the battery percent does not change even after hours. And when I disconnect the charger, the battery percentage goes down. I've tried soft resetting, checked if the battery's loose but it isn't, the phone is almost brand new. Is this a hardware issue?
RumoredNow
18,134
Can you try a different charger? Do you have a USB cable and can you try charging on a USB port from your computer? Does your computer recognize the phone?
What you want to do is determine if it is the charger or the port. If not the charger or the port it may be the battery chip.
Last ditch effort is try a Factory Reset...
jmshub
Moderator
Apr 16, 2011
2,667
Do you have another device that you can plug into the charger and see if it charges? I could see the USB cord having a broken wire inside, so it just barely makes contact. Your phone will show that it is charging, but it's not sending enough electricity to recharge the battery.
RumoredNow
18,134
535 ships with the 0.5a travel charger that does not have a removable USB cord and no data cable included... At least according to the unboxing vidz I quick scanned.
The cord on those Lumia 0.5a travel units is really thin. I can see the cord getting damaged quite easily.
kuyhaa
