Windows 10 Build 10074 -audio problem VAIO-VPCSB laptop-How can I fix my audio?
  • Start date
Hi,
My audio is gone since I have updated to Build 10074.... I've tried different ways which were suggested in different forums such as:
- restarting the windows audio related services from services.msc
-disable and enabling the sound...
- updating/ deleting and re-installing the audio driver
Also in my device manager, my audio device is shown as an unknown device where no drivers can be found for it... I even tried manually to guide it toward my available original window 7 compatible drivers and still nothing works...
please help .... I am going mad with my dear mute laptop! However I should say the UI of windows 10 rocks!:) thousand times better than windows 8 and 8.1
Thanks in advance for your help!
jacobss
