Can I get some help with an Edge security issue?
  • Start date
Edge security issues
so i installed 10240 the other day, and since that,i cant play almost anything on youtube. It says, "video cant be played in safe mode"... does someonekkno workaround to turn it off? in other browsers windows even wont allow youtube for security issue.
jojoe42
1,078
Re: Edge security issues
Seems like your computer is booted in safe mode - reboot it and start Windows normally
Matthias Verboven
42
I am having the same problem, every video I play on YouTube says it cannot be played because Youtube's safety mode is on.
You can disable safety mode on the bottom of the YouTube page, but when the page refreshes, safety mode is still on!
RumoredNow
18,134
Are you signed into YouTube? Check your user settings?
I refuse to have a YouTube account so I can't check in there for you.
In my edge "Restricted Mode" is off and I can watch some pretty adult stuff.
BevitalGlucoPremium
