    I installed Windows 10 and my sound will be okay for a little while then it goes out, when I try to test it it says it is being used by another application. I do not want to have to reboot every time. I have done that and I am still faced with the same dilemma. Please advise I am getting frustrated and ready to go back to my previous Windows.
    08-16-2015 06:12 PM
  2. RumoredNow's Avatar
    Quite likely you need new drivers. And an uninstall of the old drivers first.
    Check the OEM Support site for your device and/or the hardware component. Download new drivers if they can be found... Open Device Manager and expand the component category.
    Disable the device and uninstall the drivers for it. Reboot. Run the driver install utility you downloaded from your OEM. Reboot, even if it does not advise you to...
    08-16-2015 06:42 PM
  1. Why is the Surface Pro 3 so bad all of a sudden?
    By Mathias Lindberg in forum Microsoft Surface Pro 3
    Last Post: 11-04-2015, 10:40 PM
  2. Why wont my start button work on windows 10
    Last Post: 08-16-2015, 06:43 PM
  3. Replies: 1
    Last Post: 08-16-2015, 06:39 PM
  4. Where has my sound gone?
    Last Post: 08-16-2015, 04:59 PM
  5. Why are my games so laggy?
    Last Post: 08-16-2015, 04:23 PM
