Has anyone notice a super decrease in battery life ? .. Battery is going down at super speed... Even in battery saver mode...... Anyone else
You have a computer inside your pocket. A full fledged, what's the weather, what's the stocks, I'm playing a game, computer, insider your pocket. With that, however, battery tech hasn't improved in the last 25+ years.
Want battery life to get better? Ask God for a new battery tech, please. We've already got billions of dollars and world economies on the edge for this tech.
Now, back to the build. It's a service, that currently you're lucky enough to beta test, and have been for almost a year. Yes, there's bumps and bruises, if you don't want them, go back to 8.1 until the next build comes out and you hear of any issues that may cause harm. Stop rushing into everything Leroy Jenkins style and take a step back to relax.
any body having issues with touch settings? i think double tap to wake is the culprit...
Which touch issues are you having?
Sent from mTalk
Lumia 830 battery running fine. Let's make note of which phone is being used if we want to find a pattern.
I think there may be some indexing that occurs after update it who knows. But my Lumia 950 xl battery was not so great first day but now it has been fine. Granted it could be better but I can't put it on latest build yet.
Upgraded 640 last night. Disconnected charger at 6:30am. It's now 1:00pm. Battery down to 84%. Light use. No calls. Couple of texts. A Cortana search. Address lookup on maps.
I have a 640 as well. I'm on 8.1 and I'm wondering if I can give it a shot. I want to avoid a hard reset. Should I go for it?
Thanks. Wasn't sure since I saw a lot of good reports, but I understand that the hard reset for these builds is necessary.If you want to avoid hard reset, then i would recommend staying on 8.1, 'cause for most of us a hard reset after an upgrade is a must. It really boost ups your phone's performance. Altough you do not have to do it, but sometimes lag just takes over and phone becomes pretty much useless.
925 updated from 8.1 to 10586.11 no hard reset and no issues, updated this morning to 10586.29 and soft reset
~10 hours of charger 81% battery, some calls, in car Bluetooth and even subway surfers play for 15 min or so
IMO better than previous build
