1. Sourabh Parchure5's Avatar
    I have W10m 10586.11 installed on my 1020. And battery drain is too much.. Even on standby with Battery saver it consumes around 15% per hour. Any solution guys.
    12-08-2015 04:34 AM
  2. Dusan Randj's Avatar
    Have you done hard reset after update?
    12-08-2015 04:45 AM
  3. 9sag9's Avatar
    For 1020... Build 10586.29 is recommend.. Try fast ring ..
    12-08-2015 04:58 AM
  4. kumarss's Avatar
    Wait for two days. It will get better. Try disabling unwanted apps running in the background..
    12-08-2015 05:41 AM
  5. Chintan Gohel's Avatar
    have you checked what is consuming that level of battery? I have a lumia 1020 too and standby drain is about 0.5-1% per hour.
    What is on? wifi, cellular, bluetooth
    What can run in the background? facebook, whatsapp, etc
    12-08-2015 07:40 AM
  6. Sourabh Parchure5's Avatar
    Did a hard reset. And now its working fine.. Thank you guys..
    Chintan Gohel likes this.
    12-09-2015 06:58 AM
  1. How can I fix a Lumia 930 mic problem?
    By SUNNY CH1 in forum Windows Phone 8.1
    Last Post: 12-27-2015, 10:29 PM
  2. Why is the remaining battery incorrect sometimes w/ Surface Book?
    Last Post: 12-08-2015, 07:51 AM
  3. Problems installing build 10586.29 in my Nokia Lumia 1320
    Last Post: 12-08-2015, 04:57 AM
  4. Replies: 1
    Last Post: 12-08-2015, 04:32 AM
  5. How do I fix the latest update problems?
    Last Post: 12-08-2015, 04:06 AM
