Battery is draining even while charging, I've tried to do a soft reset but nothing works. What could it be?
  • Start date
Battery is draining even while charging I've tried to soft reset but nothing work.
The battery shows that is supposed to be charging but the battery is still draining.
Chintan Gohel
May 23, 2014
10,785
36
Re: Battery is draining even while charging I've tried to soft reset but nothing work.
additionally, how long have you had your phone? Are you actively using the phone while charging?
Which model is it?
DrPendragon
