Every other day my phone has no alert sounds and sometimes there is only silence to hear during phone calls. My alarm clock doesn't ring every morning.
The short term solution is a simple restart, but I'm wondering if a restore would be of use or if this is a permanent problem with the Lumia 930 or with Windows Phone 10?
I'm asking because I don't want to spend hours setting up everything anew if it's a known issue with either the phone or the OS. As I understand it there is little point in resetting and restoring from a backup and that a full reset is the only way to go?
Yes I know it's a bit of a noob question.
