why is my battery life draining so fast on my surface pro 3
  • Start date
why is my battery draining so fast on my surface pro 3
Chintan Gohel
May 23, 2014
10,785
36
check under battery settings to see which apps are using the most energy and disable them from running in the background
Also check for both app and OS updates
DrPendragon
