1. AgentPAK's Avatar
    Hi,
    I have an Invoke Speaker connected to a Samsung SmartThings Hub which is connected to a Lutron Hub. Using the Speaker (Cortana), I can turn any lights on and off. The problem is they will not dim. For example, If a light is 60% (which is what SmartThings is set at and I use the Invoke Speaker to dim to 20%, the light lowers for a fraction of a second and then goes right back to 60%. I have tried unlinking everything and reconnecting to no avail. I would appreciate any ideas.
    Thanks
    02-18-2018 06:16 PM
  2. realwarder's Avatar
    Have you tried using IFTTT integration?
    02-20-2018 02:37 PM
  1. Nokia Lumia 530 facebook problems - please help!
    By Impossiblegirl99 in forum Ask a Question
    Last Post: 11-24-2018, 05:56 AM
  2. Optimization and updates on Yoga Book
    By Midi_Amp in forum Other Brands
    Last Post: 02-28-2018, 06:57 PM
  3. Amazon's samples let you try before you buy and give you credit back
    Last Post: 02-16-2018, 02:30 PM
  4. Cortana now works with more smart home devices and IFTTT
    Last Post: 02-16-2018, 12:50 PM
  5. Intel slapped with 32 class action lawsuits related to Meltdown and Spectre flaws
    Last Post: 02-16-2018, 12:30 PM
