    Looking for a replacement battery for a Surface Pro 2 (1601) that went from fine to not taking a charge overnight.
    I've looked on eBay, but it seems my options are a mix of used OEM and generics from China.
    For those more familiar with batteries ... what likely the best way to go?
    02-24-2018 12:10 PM
  2. realwarder's Avatar
    It sounds a really hard battery to replace, and even Microsoft themselves have no original replacement batteries - they just offer a discount towards another newer Surface.
    Looks like generics from China may be the best option, but good luck with the repair itself!
    xandros9 likes this.
    02-24-2018 09:34 PM
  3. xandros9's Avatar
    The Surface line is generally exceedingly difficult to repair - the risk of damage and likely cost (and especially considering MS would rather sell you a refurbished unit) means you'll probably be better off getting another, easier to repair, computer. There are some alternatives out there.
    02-27-2018 10:44 AM
  1. Xbox us for uk
    By TheFaygoKid in forum Ask a Question
    Last Post: 02-24-2018, 09:43 PM
  2. Replies: 1
    Last Post: 02-24-2018, 09:39 PM
  3. Here's what PUBG will need to do to pull players back from Fortnite
    Last Post: 02-24-2018, 09:10 AM
  4. Chime in: Just how well can you use a Surface Pro on your lap?
    Last Post: 02-24-2018, 07:10 AM
  5. How to lock Lumia 640XL Win 10?
    By God 1 in forum Microsoft Lumia 640 XL
    Last Post: 02-24-2018, 06:18 AM
