    Considering buying a Surface Go but would like to use the Surface Pro 4 pen I have. Does anyone know if it will work on the Surface Go?
    08-01-2018 11:05 AM
  2. libra89's Avatar
    According to the Microsoft site, it works just fine.
    Laura Knotek likes this.
    08-02-2018 02:14 PM
  3. Alexander Long's Avatar
    yes, even the pen for surface pro 3 works as I have the pro 3 and its pen. so any pen works with N-Trig should work, just matter of pressure sensitivity, and newer one have more level of sensititie than older ones.
    libra89 likes this.
    08-02-2018 11:30 PM
  1. Chime in: Have you had a bad experience with Microsoft Surface tech support?
    Last Post: 08-01-2018, 10:40 AM
  2. Give your laptop the ventilation it needs with this AmazonBasics stand for $12
    Last Post: 08-01-2018, 10:10 AM
  3. How to fix Surface Book 2 base docking problems
    Last Post: 08-01-2018, 08:10 AM
  4. New Forza Horizon 4 footage takes you to Edinburgh in the spring
    Last Post: 07-31-2018, 07:50 PM
  5. Windows Central Podcast 99: Why Change the Shrimp?
    Last Post: 07-31-2018, 05:40 PM
