1. John Campbell8's Avatar
    I tried to follow the steps for maximizing performance you posted on the Surface Pro 4 and Surface Book. When I go to advanced settings, my Intel Graphics card settings is not listed in the menu of items to select from. That means I can't change it to maximum performance.
    07-09-2020 02:24 PM
  2. ochhanz's Avatar
    , search for Edit power plan -> change advanced power settings. Than under intel graphics ... you should find the options.
    Also if you don't care about cpu speed and only about gpu, in this same window you can set a max % for the cpu speed to allow more breathing space for the gpu.
    07-21-2020 09:27 AM
  3. Ryujingt3's Avatar
    What are you wanting to do that requires maximum performance?
    07-24-2020 06:55 PM
  1. Upgrading To Window 10
    By RsMahecha in forum Ask a Question
    Last Post: 07-24-2020, 07:05 PM
  2. Microsoft has given us no reason to believe the Surface Duo will be good
    Last Post: 07-10-2020, 03:50 AM
  3. Xbox isn't slowing down on studio acquisitions according to Phil Spencer
    Last Post: 07-09-2020, 10:42 AM
  4. Rainbow Six Siege forces you to try new Operators new Attrition mode
    Last Post: 07-09-2020, 09:11 AM
  5. Hands-on with Surface Duo's OS gestures, spanning, app groups, and more
    Last Post: 07-08-2020, 05:20 PM
