1. max2me's Avatar
    I like creating timelapses (even have an app for that ;)
    Today I finally received my iStabilizer tripod adapter from Amazon so that I could plug my Lumia on a DSLR tripod for easier recording (no more cups and other improvised tripods).
    Problem is that it's a bit too small. I have to extend it to it's fullest and them jam my lumia in there. It keeps it pretty snugged but dang - if only it would extend few mm more, I'd hate to scratch it by accident.
    So I have 2 questions:
    - Anyone had any luck adapting this particular tripod adapter for 920?
    - Are there alternatives worth looking at? (I have cheap windshield mount and it's just crap.. dont mind paying few bucks more for higher quality).
    Thank you.
    11-29-2012 12:07 AM
  2. max2me's Avatar
    Got a word from their CS - iStabilizer XL will be coming in next couple weeks and it will support Lumia 920 & other bigger phones.
    11-29-2012 07:47 PM
  3. TheZuneLune's Avatar
    Thanks for posting about this as I am interesting in doing something similar.
    11-30-2012 10:45 PM
  4. ChumsFuture's Avatar
    i bought the Case Star branded version from Amazon, it sells for only $8 shipped with Prime. i believe it's the same as the iStabilizer and it too is a rather tight fit.
    WARNING though, my mount's tripod screw piece dislodged itself from the mount. glad it only happened while mounting the unit to a tripod and not while i was doing anything extreme as i might have damaged my phone. the little piece simply pushed right back in but i'm going to need to super glue it back for a secure fit.
    12-01-2012 10:04 AM
  1. Screen width too small
    By f4jock in forum HTC 8X
    Last Post: 09-25-2012, 04:40 PM
  2. Too Big, Too Small...Just Right | Screen Sizes for new Phones
    By andrelamont in forum Upcoming & Rumored Phones
    Last Post: 09-10-2012, 08:47 PM
  3. Anyone else find the landscape keyboard a bit small?
    By TallPaul86 in forum Windows Phone 7
    Last Post: 07-14-2012, 10:23 AM
  4. Keyboard way too small for me
    By neighborlee in forum Windows Phone 7
    Last Post: 02-09-2012, 10:17 AM
