1. Joshua Jackson's Avatar
    Has anyone used the new Moga Pro Power controller with their Windows Phone, yet?
    All post that I've seen are about the old Moga Pro.
    Specifically, I want to make sure that it actually charges the phone while playing.
    Given the amount of replies to other posts that say it isn't "supported", I feel inclined to say that I know it isn't officially supported.
    But, we all know that things that aren't officially supported can work just fine.
    JJ
    01-09-2014 02:33 PM
  2. Paul Acevedo's Avatar
    There's no reason it wouldn't power the controller. And word is that all Moga controllers work with Windows Phone 8.
    01-16-2014 11:22 AM
  3. mase123987's Avatar
    I created this thread awhile ago: http://forums.windowscentral.com/win...ml#post2278816
    It is dedicated to list Moga supported apps. I am subscribed to the thread. So, anytime you add a post with a new game, I will add it to the top post with a day or so.
    It should allow you to keep up with the scene.
    01-16-2014 07:52 PM
  4. darkest.white's Avatar
    I just ordered one so I can let you know but yes I'm sure it would work. A batter and cable will charge like any other method and the controller is just the same as the others, just fancied up. So pumped by the way haha
    Paul Acevedo likes this.
    01-19-2014 12:02 AM
  5. darkest.white's Avatar
    So it got here on Friday and yes, it works great. A little tricky to setup, took a few tries, but it works!
    AkAdam likes this.
    02-09-2014 05:08 PM
  1. Inline volume control cable
    By Rafael Boscan in forum Nokia Lumia 920
    Last Post: 01-29-2014, 04:22 PM
  2. Question regarding MoliPlayer Pro
    By Lance_WPCentral in forum Applications
    Last Post: 01-22-2014, 05:40 AM
  3. Dell Venue Pro 8 Wireless Keyboard Case
    By mister2d in forum Marketplace Archive
    Last Post: 01-09-2014, 01:23 PM
  4. Replies: 2
    Last Post: 01-09-2014, 11:25 AM
  5. Replies: 4
    Last Post: 01-08-2014, 08:07 PM
