1. jrodd09's Avatar
    I want to purchase the deal of the week TYLT VU QI Wireless Charging Pad but it says that it doesn't work with L1520 however, I thought the unlocked version was QI compatible?
    Can some one clear this up for me?
    Thanks!
    03-02-2015 10:56 AM
  2. pankaj981's Avatar
    When you say unlocked version I hope you're referring to the non-AT&T version. If its an international variant and support Qi wireless charging then yes it should work, if its the AT&T unlocked version then it won't
    03-02-2015 09:02 PM
  3. MSFTisMIA's Avatar
    As a former 1520 user (the unicorn 1520.3 to be exact) and a proud owner of this charger for going into two years, it works just fine as long as your 1520 isn't the AT&T model.
    03-02-2015 09:19 PM
  4. jrodd09's Avatar
    Mine is the: Nokia Lumia 1520 RM-938 32GB Smartphone (Unlocked, White) sorry not that technical and don't want to purchase something that doesn't work
    03-03-2015 09:11 AM
  5. pankaj981's Avatar
    Yes it should work
    03-03-2015 07:59 PM
  1. How do I fix the error code: 80048264
    By WPCentral Question in forum General Phone Discussion
    Last Post: 11-13-2016, 02:29 PM
  2. Replies: 6
    Last Post: 01-19-2016, 07:01 AM
  3. Replies: 12
    Last Post: 03-19-2015, 04:54 AM
  4. Which Phones work on Verizon
    By Justinius in forum Windows Phone 8.1
    Last Post: 03-02-2015, 12:38 PM
  5. Can you change a Lumia 735 on the charging plate if its in a leather case?
    Last Post: 03-02-2015, 10:49 AM
