Battery percentage while charging?
tyrok
16
Is there anyway to see the battery percentage while charging? The icon just changes to to a plug with no info. I know it does say the percentage in watch mode or if you are using a computer with the app loaded but it seems weird that there is no indication that it is done charging without those two things.
tyrok
16
When it is charging the battery icon in the pull down just has a plug over it. No indication of how much more charging is needed.
dwlovell
37
Yes, turn on "Watch Mode" (setting tile...clock tile). Then when you connect the charger and turn off the display, the "Watch mode" display will have the current battery as a numerical %.
rogertewarte
