Preorders are now LIVEfor all of the new Surface devicesfor Fall 2021
05-25-2016 04:27 PM
41 12
tools
  1. Dave47's Avatar
    Just got off the phone with the folks at Microsoft Band support. Wanted to make them (more) aware of the Band 2 "thinks the battery is dead" problem. They said they were aware of the problem and that it's being worked on. I'm on my second B2 because of this problem and I'm not alone.
    Maybe if a few (many) more B2 owners call, this issue will get a priority boost to get fixed. Maybe.
    Here's the number I called (in the US) : 425-635-2970
    paescebu likes this.
    12-13-2015 11:01 AM
  2. Likwidz's Avatar
    My gf's doing the same thing. Going to swing by the store today to try an get a replacement
    12-14-2015 11:27 AM
  3. maxmin's Avatar
    Mine just did that too. Shut down unexpectedly and when I connected the charger it showed 70% charge. I might try a hard reset to see if it helps.
    12-14-2015 08:47 PM
  4. balefire's Avatar
    Same problem. Band died with plenty of power. Replaced it. Occurred again. Will see if update fixes...
    12-15-2015 01:54 AM
  5. Dave47's Avatar
    Last week's update does NOT fix the problem. Some are saying it's a problem with the clasp mechanism. I dunno but I do know MSFT is aware of the problem. If it is the clasp, then our friends in Redmond have one hell of a job facing them in terms of getting the fix out to the masses.
    paescebu and sahib lopez like this.
    12-15-2015 07:10 PM
  6. DroidUser42's Avatar
    Clasp? I wonder how the clasp could affect that? Although..... you don't suppose they'd be dumb enough to expose raw power on those charging contacts and they're getting shorted out?? You might try putting something over the contracts or the surface they would touch and see if that resolves the problem.
    12-15-2015 10:17 PM
  7. Dave47's Avatar
    Well the clasp is where the battery is and there are 5 gold contacts on it that the magnetic charger cable snaps in to. That means there's a cable in there that routes power to the display/guts of the rest of the B2. Maybe if the clasp gets "jiggled" in a certain way, it causes the problem. I don't know. But I trust someone at MSFT does by now and a fix is being worked on.
    12-16-2015 11:13 AM
  8. acountryman's Avatar
    Have the same issue here. Filled to 100% battery. Can open and close the Band 2 with the button, but once you put it on it acts dead.
    12-16-2015 01:49 PM
  9. DroidUser42's Avatar
    Perhaps the tension on the power cable from wearing it. What happens if you put the battery to display part of the band under some tension?
    12-16-2015 03:20 PM
  10. Dave47's Avatar
    If devbent is reading this -- any comments / updates on this issue? Seems to be affecting many B2 owners.
    And thanks for checkin' in here.
    12-17-2015 10:55 PM
  11. paescebu's Avatar
    Hey all, I just registered here to make my statement.
    My Band 2 is affected as well and following the support forum of the band 2 page, many others are as well.
    It really seems to be the clasp mechanism pulling off that issue, and if it is true, than MS is in big trouble, since a design or HW failure is so expensive to fix. Additionally, this would really damage their image (again ) .
    I have a big list of links to forums with threads of people having this exact issue (but since im newbie here im not allowed to post links)
    I tipped windowscentral to write an article about that (since wmpoweruser refuses to write one [fanboys much ]) in hope to push MS a little with their research and solution finding.
    short the issue looks as followed:
    1. Band turns off /screen turns black
    2. Can only be turned on when plugged into the charger
    3. After plugin the band displays an error message: battery ran out, please enter date and time
    (even though battery was full)
    4. After a few minutes it turns off again..making it totally unusable
    (but only with a closed clasp)
    Dave47 likes this.
    12-18-2015 07:33 AM
  12. paescebu's Avatar
    ok, yesterday I received the replacement band 2 and guess what, same issue again (but I needed a little more force to trigger this effect, had to use the clasp more violently), this one is going back to MS again..keep in mind..this is a brand new band 2..i just cant believe that..
    12-20-2015 12:26 PM
  13. Likwidz's Avatar
    I'm curious what size are all of your Bands that are having the issue?
    12-20-2015 02:46 PM
  14. Dave47's Avatar
    For those interested, here's a band support # from an email received today from Microsoft
    800.642.7676
    12-20-2015 04:31 PM
  15. Dave47's Avatar
    Just got another email from the Band support folks. MSFT is fully aware of the problem and it is being worked on. No ETA for the fix.
    IMO, if it's H/W (and it looks like it is) that will be much harder to handle than pushing out a S/W or F/W fix. We'll see.
    12-22-2015 09:18 AM
  16. mightybrick's Avatar
    Just chiming in to say I'm having this same problem with my Band 2 purchased 3 days ago, and to subscribe to the thread for updates. I'd done a little searching before purchase, but hadn't come across this. Bummer that I'll probably have to return it. Can't get much use out of a device that won't stay on. :(
    12-31-2015 06:09 PM
  17. BBJonbo's Avatar
    Just happened to me last night. Support call states same thing and that I needed a replacement. They refuse to comment on whether this is hw or sw issue or both. like others, I believe due to their silence and providing no details it is likely hw. I have passed the 30 day refund period so looks like I may get a new band every 4+ weeks for the next 2 years or until they finally figure this out.
    01-01-2016 02:06 PM
  18. BBJonbo's Avatar
    Ran down to local MS store and they replaced my B2 with no hassles. Even gave me a new Zagg screen protector. Will see how long this one lasts. Hopefully until the permanent solution is available. Glad MS made the exchange process hassle free.
    01-01-2016 08:15 PM
  19. Dave47's Avatar
    Got another email from the MSFT support folks. They wanted to close my B2 problem case because it is in the hands of those responsible. I asked to keep it open so I could get occasional updates. They said OK. Now that the holiday season is winding down, maybe we'll see a solution soon. Maybe.
    01-02-2016 08:33 AM
  20. Fritz Anker's Avatar
    Well, this sucks. Mine started doing this yesterday. Guess, will be going to the MS store soon for a replacement. Drrr...
    01-03-2016 01:46 PM
  21. Exhibit13's Avatar
    Got mine on release day and just last night mine shut off with ~50% power, today I tried to charge, reset, etc and it just keeps shutting off once unplugged and clasp touches. I purchased mine from Amazon will the MSstore swap mine out or did you have to purchase there to get them to swap it?
    01-03-2016 11:29 PM
  22. E D B's Avatar
    I purchased mine through preorder from Microsoft online store, and swapped it just a few days ago at their local store. No question asked. I believe as long as it is within warranty, the local store will just exchange it with a new one.
    01-04-2016 11:58 AM
  23. beman39's Avatar
    great count me in on this problem too! I just got my watch a month ago! going to contact MS later today when they open...
    01-22-2016 12:03 AM
  24. bellyer's Avatar
    I just got hit with this issue. I got my Band 2 on the day it went on sale. Guess I'm lucky it lasted this long
    01-22-2016 04:36 PM
  25. Mike Santagata's Avatar
    So its not just me, huh...
    01-22-2016 04:57 PM
41 12
  1. Any news on the 950\XL update fix
    By outoftime84 in forum Windows Phones
    Last Post: 12-17-2015, 01:49 AM
  2. Groove Music problem, with 10586.29 mobile
    By Jaripi in forum Windows Apps
    Last Post: 12-16-2015, 09:39 AM
  3. Replies: 1
    Last Post: 12-13-2015, 09:58 AM
  4. Why is my Windows 10 PC updating to Windows 10 again?
    Last Post: 12-13-2015, 08:18 AM
  5. Windows 10 Update Stuck at 78% . Don't know why :(
    Last Post: 12-13-2015, 07:48 AM
