technical charging question
Hi guys, a little bit of a technical question here but important to keep the battery as fit as possible.
The problem: there is no charging unit supplied in the Band 2 package, only a charging cable. Question is: What kind of charger do I have to put the Band 2 on? On the Microsoft site they are only talking about charging it on the PC, but how about standalone chargers?
The one that came with my lumia is 5V / 1,3A. Since the Band 2 has a Lithium Polymere battery, which optimally should be around 3.7V, I was wondering if I might destroy battery capacity by charging my Band 2 with this. And how about using the well known "Fast Chargers"?
Since Microsoft didn't supply a charging unit I am kinda suprised I can't find any info about which charging unit to use on the Microsoft support page.
