Jan Tomsic
Re: AMD vs Intel
1) I'd consider WD Green because it's big and cheap. If you read my post (which you obviously didn't, otherwise you wouldn't be asking this question), you would see that I'm recommending two options: 1. WD Blue 500GB and 2. WD Green 1TB + Crucial 120GB SSD
2) This is a supposed to be a budget PC, again, if you read my post, I'm explaining my choice for single 4GB RAM: you MAY not need more, but IF you do, it's very easy to upgrade later. 1333 or 1600, whatever, the difference in performance is maybe 5%. If you want faster and more RAM, it's 86,53 ? for Crucial Ballistix 1866MHz, 2x4GB. Final price in this case: 458?.
I don't think 1866MHz RAM is really going to improve any performance considering we're running a core-i3 here.
3) The list is super easy to read (there's pictures and all), all the brands are appeared, but let me translate it for you:
- chassis fan Arctic Cooling F12, 120m - 7,83?
- RAM Corsair DDR3 4GB 1333 MHz - 42,14?
- CPU Intel Core- i3 4130 - 107,54?
- PSU LC Power Silent LC5550 V2.2 550W - 43,94?
- motherboard Asus H81M-K, 1150 - 48,91?
- HDD WD Green 1TB, 7200rpm, 64MB, SATA3 - 60,80?
- SSD Crucial M500, 120GB, SATA3 - 77,44?
- chassis: the cheapest one (Spire CoolBox 503, w/o PSU, black) - 25,62?
Total cost: 414,22?, and it should be less in Germany/Austria.
OP says his budget is around 400?, 500 tops. I made a configuration for 415?, of course, you can make a better one for more money, but this is what 400? will get you.
You can get WD Blue instead of Green+SSD and it saves you 75? that you can invest in more RAM and discreet GPU. Then you can get any GPU for <120? and still be under 500? (but not even close to 400 anymore).
Why would you even consider a green drive in the first place? The blues are faster, more reliable, and cheaper, so why get the green? Also, 4 GB is fine for some, but it's definitely not fine for all. I upgraded my RAM in 2012 because I was hitting the 4-GB ceiling on my desktop. RAM's cheap, so going with 8 GB usually doesn't cost much. Oh, and 1333 RAM is bottom-of-the-barrel, not sure why you would waste your time with it.
Beyond that, I can't read the list because it's in another language and isn't appearing to have the brands on the parts every time. I have no idea what the case or PSU brands/models are, so I can't say if they're worth a darn.
Oh, and when we're talking about nearly-max graphics and a longevity of 3-4 years, Intel's graphics aren't going to cut it. Maybe on the lowest settings, but it's sketchy for more than a short-term fix.
