Jarip
Re: AMD vs Intel
Everything change but slowly - it will take a long time until DDR4 prices will be even close DDR3 prices and I think that CPU sockets change too ....
By the way, Haswell is good way to go ... I was trying to tell you that invest more money for GPU and buy cheaper Intel G3420 dual core (Haswell) CPU, as it is a nice combo to have Intel Pentium G3420 dual core CPU with a AMD Radeon R7 250 GDDR5 or Radeon HD7770 or even with R7 260X GDDR5, if you have budget ...
... and buy SSD Kingston HyperX 3K 120 Gb (instead of WD HDD) and you have a great system
... and do not buy AMD Kaveri A10-7850K, as you will not use integrated graphics for gaming (and it would cost you even more as a CPU + GPU combo some I suggested for you) ...
... yeah, i3-4130 is better one compared on G3420, if you have budget for it ... but more important is better GPU, so use that saving to a good GPU ... and even if you decide to upgrade G3420 later to i5 or i7, your investment was not that big for G3420
How long will DDR3 remain, since the first DDR4 stuff will be available in July? Also, it looks like a Haswell-Refresh is comming soon. Should I wait or is the difference not worth the wait/price?
