WP7 Memroy leak issue in navigation - Listbox binding
phpfreek2007
Hi,
I am developing one application in Silverlight for windows phone 7. I am stuck in very common issues which comes in windows phone app however not able to get out of it in any ways. It is memory leak issue which comes during navigation from first page to second, second to first and so on for multiple times.
To solve it, i create one new project having 2 blank pages. Each page has 2 text blocks to print current memory and peak memory and one button to move to next or previous page. When navigate from page 1 to page 2, i make null referance of all 3 things and call gc.collect to destroy the page referance. Same way, while moving from page 2 to page 1, i do the same thing.
I also tried to call gc.collect() in timer for every 500 mili seconds, but still no result. If i remove gc.collect() totally, memory increases in MB so i think it is a must thing.
Here is snippet of my code:
Main Page:
using System;
using System.Collections.Generic;
using System.Linq;
using System.Windows;
using System.Windows.Controls;
using Microsoft.Phone.Controls;
using System.Windows.Threading;
namespace AppMemory
public partial class MainPage : PhoneApplicationPage
// Constructor
public MainPage()
InitializeComponent();
txtCM.Text = "C : " + Microsoft.Phone.Info.DeviceStatus.ApplicationCurrentMemoryUsage.ToString();
txtPM.Text = "P: " + Microsoft.Phone.Info.DeviceStatus.ApplicationPeakMemoryUsage.ToString();
// Simple button Click event handler to take us to the second page
private void Button_Click(object sender, RoutedEventArgs e)
NavigationService.Navigate(new Uri("/Page1.xaml", UriKind.Relative));
protected override void OnBackKeyPress(System.ComponentModel.CancelEventArgs e)
while (this.NavigationService.BackStack.Any())
this.NavigationService.RemoveBackEntry();
protected override void OnNavigatedTo(System.Windows.Navigation.NavigationEventArgs e)
protected override void OnNavigatedFrom(System.Windows.Navigation.NavigationEventArgs e)
dosposeMemory();
base.OnNavigatedFrom(e);
this.DataContext = null;
GC.Collect();
public void dosposeMemory()
try
if (txtCM != null)
txtCM.Text = null;
txtCM = null;
if (txtPM != null)
txtPM.Text = null;
txtPM = null;
if (btn1 != null)
btn1.Click -= Button_Click;
btn1.Style = null;
btn1.Resources.Clear();
btn1.Resources = null;
btn1 = null;
if (ContentPanel != null)
ContentPanel.Children.Clear();
ContentPanel.Resources.Clear();
ContentPanel.Resources = null;
ContentPanel = null;
if (LayoutRoot != null)
LayoutRoot.DataContext = null;
LayoutRoot.Background = null;
LayoutRoot.Resources.Clear();
LayoutRoot.Resources = null;
LayoutRoot.Children.Clear();
LayoutRoot = null;
if (app1 != null)
app1.Resources.Clear();
app1.Resources = null;
app1 = null;
GC.Collect();
catch(Exception)
~MainPage()
System.Windows.Deployment.Current.Dispatcher.BeginInvoke(new System.Action(() =>
GC.Collect();
Second Page:
using System;
using System.Linq;
using System.Net;
using System.Windows.Documents;
using System.Windows.Input;
using System.Windows.Media;
using System.Windows.Media.Animation;
using System.Windows.Shapes;
namespace AppMemory
public partial class Page1 : PhoneApplicationPage
public Page1()
textBlock1.Text = "C : " + Microsoft.Phone.Info.DeviceStatus.ApplicationCurrentMemoryUsage.ToString();
textBlock2.Text = "P: " + Microsoft.Phone.Info.DeviceStatus.ApplicationPeakMemoryUsage.ToString();
NavigationService.Navigate(new Uri("/MainPage.xaml", UriKind.Relative));
dosposeMemory();
GC.Collect();
try
if (textBlock1 != null)
textBlock1.Text = null;
textBlock1 = null;
if (textBlock2 != null)
textBlock2.Text = null;
textBlock2 = null;
LayoutRoot = null;
if (page1 != null)
page1.Resources.Clear();
page1.Resources = null;
page1 = null;
GC.Collect();
catch (Exception)
GC.Collect();
Here is tracking of Current Memory which is increasing in each try:
Try Page 1 Page 2
1 74266048 7442432
2 6959104 8257536
3 6934528 8454144
4 8622080 8458240
5 8626176 8470528
6 8630272 8470528
Questions:
1) Is my flow and method proper for navigation from and back to manage memory?
2) Is my method to make referance null for text block and button is proper?
3) Also in my actual project, i am using databinding in listbox which i have destrcuted in following way.
if (listCountry != null)
listCountry.SelectionChanged -= listCountry_SelectionChanged;
//listCountry.Items.Clear();
listCountry.DataContext = null;
listCountry.ItemsSource = null;
listCountry.Resources.Clear();
listCountry.Resources = null;
listCountry = null;
I have doubt in this since in my project, there are multiple usage of such listbox.
Please take me out of this since i have spent lots of time in research and updates but not got the solution for current and peak memory.
Thanks in advance.
Hello,
There are a couple questions to consider: Are you noticing this memory increase even after navigating backwards to the previous page using the back button? Pages are not immediately destroyed once you navigate away from them unless you remove them from the Back Stack.
In addition, is there anything else which could possibly be holding references to your Pages? Think of anywhere you might have passed a reference to the page.
Also, think of any kind of custom controls or behaviors you use. Basically anything not in the SDK. It could be that they're causing a memory leak.
Regards,
Nelson
yagoldt
