1. Moiz Mian's Avatar
    Hi guys,
    So I am getting a replacement windows phone through my carrier, and in order to upgrade the new phone to gdr3, do I need to remove my phone from my developer account or anything like that? Or can I just download the preview app and upgrade it just like my current phone?
    I'm just hoping there is no restriction for "one phone only" and if I have to remove it from the old phone before being allowed to put it on the new one.
    Thanks!
    11-24-2013 03:43 AM
  2. Exotic Hadron's Avatar
    Nope, you don't have to do anything else. What's your device?
    If you're using Samsung ATIV S, to get the official GDR3 (Update 3) upgrade your CSC code, Customer Sales Code, must be ATO (Austria). But once you do that, you won't be able to use the trick to interop-unlock your phone and gain access to its registry and file system.
    Upgrading to GDR3 Preview should be fine, but keep in mind that this update has a flaw that kind of bricks your phone if you do a hard reset. Hard resetting your phone on Update 3 Preview will end up with a black screen after welcome screen, you won't see no UI.
    11-24-2013 04:34 AM
  3. Moiz Mian's Avatar
    I have a Lumia 920. I am unaware of the hard reset bricking the phone! That can't be right
    11-24-2013 02:21 PM
  4. Mantraxalos's Avatar
    Unless the problem is samsung specific, i have gdr3 on the 1020 and have done multiple hard resets without any problems.
    11-28-2013 08:44 AM
  5. Loco5150's Avatar
    And there is also already a solution how to keep interop unlock on a Ativ S when updating to official gdr3.
    11-28-2013 08:53 AM
  1. Cannot get a 521 working on StraightTalk
    By link9454 in forum Windows Central Archive
    Last Post: 06-04-2014, 10:18 AM
  2. HTC 8x stuck on 0xc000021a error
    By Italo Pereira in forum Windows Phones
    Last Post: 12-23-2013, 01:39 PM
  3. HTC GDR3 owners have one question to you)
    By AV2RY in forum Other Operating Systems
    Last Post: 11-23-2013, 07:16 PM
  4. cant talk and text on lte
    By superlawyer15 in forum Windows Phones
    Last Post: 11-23-2013, 04:11 PM
