Need some help with developing
itsonlyjames
4
I have windows 8.1 installed, so i should be able to code wp 8 apps, but i only have a 32 bit machine, which means i cant use the 8.0 sdk
And now because i'm using windows 8.1 i can't install the 7.1 sdk because it has any compatibility issues.
Does anyone have any idea what i can do?
drg
186
Upgrade/re-install Win8.1. It won't cost a thing. Just need to get your hands on the 64-bit installer. You product key will still work on it. You can then write apps for both WP8 and WP7 with Visual Studio for Windows Phone.
itsonlyjames
4
I'm using Win8.1 at the moment, but my system is only 32-bit compatible. i'll just have to upgrade my system. Thank you for your reply though!
NunezGuad
