Originally Posted by
gurpreetsingh793 Oh wait, I just remembered one thing: some years ago the 2 front USB ports stopped working so since then I am using the 4 ports at the back. Could it be related to those front USB ports? BTW their pinouts(or whatever they're called) are disconnected from the motherboard since.
Remove AC plug, and check mobo pins, maybe are dirt on bended togheter.
Why you stopped using that? phisycal damage / do device plugged working?
That could be that, a faulty controller, so o.s. continuosly tries to reinstall it. But try to clean and unbend pins, and re-plug front usb ports, without using that
