Verizon trophy battery
kregstrong
274
Does anyone know where I can get an extra battery or extended one for this phone?? I tried amazon but can't find one. Thanks
Sent from my htc trophy using Board Express
selfcreation
3,287
9
thed
992
3
It depends which battery you're talking about. HTC makes 2 batteries for the incredible. The 1300 mAh battery is the same battery that the trophy uses. The 1500 mAh battery is slightly thicker and will not allow you to replace the battery door on the trophy. Just make sure it's the part number that I listed above and it will fit.
Sent from my HTC Trophy using Board Express
scottd34
51
vzw.com has the batteries, and you can call up and order one. If youre going ot buy from a store, try the corporate stores first. Resellers buy their own inventory so they arent necessarily going to have it.
DrPendragon
