1. wilsey's Avatar
    I just got Lumia 920 for a week now and still trying to figure out a decent apps (I usually find these apps on Best Rated section) that don't drain the battery pretty fast in the background or while not in use. As some of the apps, even though, you have exit it, it will still run in the background and unable to block it. The only app that can be blocked is Nokia Drive Beta. And currently under the Advanced tab on the Background Tasks, I still have 7 apps running.
    Any suggestion? T
    Thanks a lot for the help
    Does anybody uses WeChat? As I think this is a decent app but drain the battery pretty quick even I haven't used it at all. After I installed it, usually at night I unplugged the fully charged phone, and in the morning after 7 hours, it will still stay at 100%, but after I installed it, the next morning when I woke up, it has drained the battery to 83%. Gonna try it again tonight to see.
    01-02-2013 06:03 AM
  2. dipayanster's Avatar
    i am using icq for gtalk-im and accuweather live tile on wp7.8. they have almost negligible footprint on battery back up as i found.
    wilsey likes this.
    01-02-2013 06:21 AM
  3. wilsey's Avatar
    Thank you for the suggestions. :D
    dipayanster likes this.
    01-04-2013 01:44 AM
  1. Why does text based apps drain the battery so much?
    By jdhooghe in forum Other Operating Systems
    Last Post: 12-27-2012, 04:08 PM
  2. Replies: 5
    Last Post: 11-20-2012, 12:16 AM
  3. Replies: 14
    Last Post: 11-18-2012, 01:27 PM
  4. How to increase the number of decent apps in the Marketplace
    By adamopinheiro in forum Other Operating Systems
    Last Post: 12-12-2011, 08:02 PM
  5. Is there a contact tile in Mango or just the people tile?
    By Bballbenb in forum Other Operating Systems
    Last Post: 11-06-2011, 10:55 AM
