1. yeto's Avatar
    For my job, I need to be able to prove my location. My company will allow me to do this using my phone if I can come up with a way. Is there an app available that will show my gps location and then maybe I can take a picture of the screen using the front facing camera and a mirror? Would this even work? Could anyone offer some ideas or suggestions that might be easier/better?
    Thanks in advance for any help,
    yeto
    03-07-2013 03:54 PM
  2. David Best's Avatar
    you could use any map app to find your location then take a screen shot and send it via email
    03-07-2013 04:00 PM
  3. Badranath17's Avatar
    You can send your location in a text message. When writing a message just tap attach and my location.
    03-07-2013 04:01 PM
  4. jhguth's Avatar
    the idea of using a mirror to take a screenshot is pretty funny
    03-07-2013 04:32 PM
  5. yeto's Avatar
    Is there an app I need to download to take a screenshot?
    Thanks,
    yeto
    03-07-2013 04:41 PM
  6. Olerius's Avatar
    None at all. On most Windows phones, just press the power button at the same time as the Windows key/icon.
    Badranath17 has it right though; it's much easier to just click "add location" (unless you're hoping to build a catalogue of mock locations to send in to work).
    03-07-2013 04:48 PM
  7. raul_junior's Avatar
    ya just in the text messaging just press the "attach" and press "location"
    03-07-2013 04:48 PM
  8. Goku1982jason's Avatar
    Just hold the sleep/wake button and the windows button at the same time. Then the screen shot will be saves to your albums under screen shot
    03-07-2013 04:49 PM
  9. yeto's Avatar
    I tried your suggestion and that works great. Thanks for taking the time to reply.
    03-07-2013 04:50 PM
  10. Badranath17's Avatar
    No problems glad I could help.
    03-07-2013 06:34 PM
  11. eeewing's Avatar
    Apps like echoecho will allow others to track your location in real-time, too.
    03-08-2013 07:42 AM
  12. DonMorris's Avatar
    You could use Google Latitude, I think there are a few third-party apps in the store which allow you to use the service:
    Buddytude – a Google Latitude app for Windows Phone | WMPoweruser
    03-08-2013 08:00 AM
  13. ImmortalWarrior's Avatar
    Gmaps pro has latitude but GPS Calculator lets you do raw GPS calculations as well. With GPS calc you can get the raw lat and long and take a screenshot.
    03-08-2013 08:30 AM
  14. yeto's Avatar
    Thanks to all who replied. Very helpful information.
    Kind regards,
    yeto
    03-09-2013 05:56 AM
  1. Things I'd like to be able to do with WP8 that I can't.
    By Dano 32 in forum Other Operating Systems
    Last Post: 01-07-2013, 08:34 PM
  2. Replies: 6
    Last Post: 12-09-2012, 02:18 PM
  3. Replies: 2
    Last Post: 12-09-2012, 11:26 AM
  4. Anything the Acer Iconia W500 will not be able to do?
    By Bballbenb in forum General Desktop, Laptop & Tablet Discussion
    Last Post: 05-07-2012, 03:40 AM
  5. questions about my trophy, you might be able to help?
    By sangwl in forum Windows Central Archive
    Last Post: 06-03-2011, 01:41 PM
