1. Beau Beerlage's Avatar
    Are there more people experiencing a battery drain after updating to the latest version of Chronos Calendar?
    After my update yesterday, during one night I lost 30% of battery and after recharing completely I lost another 20% within 1,5 hours without any use at all and after a restart.
    Not saying it is the app, but for me it could explain the issue with my battery.
    03-19-2013 07:53 AM
  2. Jazmac's Avatar
    I haven't noticed it on my phone so far.
    03-19-2013 08:59 AM
  3. Manojkumar_25's Avatar
    Can you please check in background apps. Might be that's the reason.
    03-19-2013 09:01 AM
  4. Beau Beerlage's Avatar
    Restarted my L920 twice, so there are no background tasks active.
    03-19-2013 09:05 AM
  5. Jaripi's Avatar
    You can use it with sync or without sync (go Chronos settings to deactivate it, if you like that way - I do that way) - you can not block that by other away (Chronos is also in advanced background settings, some you can not block) ... blocking Chronos visible background setting just stop updating of a live tile - do you really want it ?
    I use Chronos as deactivated and with active live tile (unblocked visible background task) ... it consume less power that way ...
    03-19-2013 10:10 AM
  1. battery drain after mysterious HTC update for skype!
    By Shodan_HR in forum Windows Phones
    Last Post: 02-12-2013, 11:51 PM
  2. Replies: 21
    Last Post: 12-18-2012, 09:06 AM
  3. Battery Issues after Update
    By LowRentTechGuy in forum Windows Central Archive
    Last Post: 05-04-2012, 12:46 AM
  4. Longer Battery Life After Applying Updates?
    By db4williams in forum Windows Central Archive
    Last Post: 04-25-2012, 04:36 PM
  5. Battery life a lot WORSE after update?
    By trmnta82 in forum Windows Central Archive
    Last Post: 02-10-2012, 07:33 AM
