Watch the June 24Windows 11 event right here
  1. Rickosw's Avatar
    Hi Friends,
    I downloaded this weatherphoto app (Ciel) Ciel | Windows Phone Apps+Games Store (United States)
    Quite like the format and app , able to post holidays pics with location & weather onto Facebook via the app (Ciel)
    As I have two Facebook accounts, I am unable to log out of the first one....any advice?
    ie after I post the pics onto the first FB acct, i am stuck in that acct , i cant log out and post into my other FB acct...
    04-03-2013 04:30 AM
  2. Punataro Chaturaphit's Avatar
    the log-out button will come with the next version, right now you'll need to uninstall-reinstall the app to switch Facebook account, sorry for any inconvenience! and glad you like the app :)
    Rickosw likes this.
    04-03-2013 01:17 PM
  3. unstoppablekem's Avatar
    I suggest uninstalling the app then installing it again.
    Rickosw likes this.
    04-03-2013 01:33 PM
  4. Rickosw's Avatar
    Hi Punataro Chaturaphit
    Are you Ciel developer ? Thanks for your reply ... ok i will look forward to your next update. Yes, i like this app a lot and after i posted Ciel Weatherphotos on FB, my friends "LIKE"...commented it is a nice little app...but unfortunately they cant use cos they are not on windows phone o/s....hehe
    Cheers!
    04-04-2013 01:47 AM
  1. Replies: 0
    Last Post: 11-27-2012, 01:37 PM
  2. Help Request: How to use NFC to receive files?
    By tarzanmarzan in forum Other Operating Systems
    Last Post: 11-22-2012, 11:11 PM
  3. How to sign out from Windows Live?
    By Quarien in forum Windows Central Archive
    Last Post: 11-04-2012, 04:56 AM
  4. Forgot to log out off store phone
    By LeoBloom. in forum Other Operating Systems
    Last Post: 04-30-2012, 11:20 PM
  5. How to log in to xbox live using separate windows live id?
    By Desdemona in forum Gaming Discussion
    Last Post: 11-09-2011, 07:26 AM
