1. wilsey's Avatar
    I'm not sure if our WP8 supports Wireless USB. It's ok for now. But is there any wireless charger out there that can have the wireless data transfer capability when we charge our phone. I think for the wireless charger to work that way, the power source must be drawn from USB port.
    It just like when we plug our phone using USB cable to computer, it can charge and transfer data at the same time. So when we put the phone on the wireless charger, we can transfer data wirelessly to our computer as well. Is this thing possible?
    05-30-2013 09:33 AM
  2. Curtieson's Avatar
    WP8 will not do the wireless sync like it did on WP7 (for music). It doesn't need to be plugged/charging in to wireless sync your camera with your SkyDrive though, that happens automatically, as long as you didn't turn that off.
    05-30-2013 09:46 AM
  3. wilsey's Avatar
    Yeah, that WP7 feature will be missed.
    The reason I asked for this feature, as I found wireless charging is so much more convenient. So I just thought if this kind of feature would be possible for transferring data. When I put on my phone on the wireless charger, the computer can detect it like when we plug it using USB cable, then we can copy documents, songs, ringtones, or photos to our phone.
    05-30-2013 10:19 AM
  4. Curtieson's Avatar
    No. They would be two separate connections.
    Nothing about the Qi charger would deal with data at all, so YES, your phone COULD connect to your WiFi and thus your computer while it was on a Qi Charger, but it would not be like plugging it into the computer via USB.
    05-30-2013 02:13 PM
  5. wilsey's Avatar
    I just hope that this kind of feature would be incorporated in the future. I find it very convenient for me to have that feature, so I don't need to keep on plugging and unplugging my phone to transfer files to my computer and vice versa.
    06-02-2013 01:33 AM
  6. Curtieson's Avatar
    Very much so! It is an incredibly handy feature...and we HAD it in WP7, we just lost it.
    Anyway, you have the feature already too if you use SkyDrive. That is the catch 22 to the whole system, the big companies want you on THEIR website, so they are really pushing the cloud storage as a way to get you into their eco system.
    06-03-2013 07:50 AM
  1. Replies: 27
    Last Post: 02-16-2014, 01:16 PM
  2. Problem getting free wireless charge plate with ATT preorder
    By tapiocamilktea in forum Windows Phones
    Last Post: 11-07-2012, 10:24 AM
  3. Free wireless charging plate with Lumia 920 @ Phones4u (UK)
    By Andy_McG84 in forum Windows Phones
    Last Post: 11-02-2012, 05:03 AM
  4. Universal Nokia car holder with wireless charging
    By Colaolli in forum General Phone Discussion
    Last Post: 10-30-2012, 10:21 AM
  5. Replies: 3
    Last Post: 09-14-2012, 07:21 PM
