Problem: rowi lite opens links in same tab
ronfouchier
6
Hi there,
until recently rowi lite worked just fine for me, but after the update to Windows Phone 7.8 I noticed that rowi opens links in the same IE tab. If I remember correctly rowi used to make use of all 6 tabs, before replacing the content of the most recently opened tab, when opening another link.
Now I select a link from my twitter stream and it opens up in an IE tab. I hit the back button, choose another link and select "go to" again. Instead of using one of the reminaing five tabs the link is opened in the only open tab.
Any ideas?
Cheers,
Ron
PS: I'm running rowi lite 2.4.0 on a Samsung Omnia 7 running Windows Phone 7.8.
Figured out where I went wrong. You need to change the setting in IE in order to open links in new broswer tabs. No problem with rowi at all.
Marchwind1949
