I have been using Amazing Weather HD for a while now but I decided to jump on Weather Flow when it went on sale. Immediately I really liked the live tile and decided I would use it, and use Amazing Weather HD for detailed weather information (since Weather Flow is lacking here) and for the lock screen. First I decided to compare the two live tiles, double wide and really see which one I preferred. After a few days, I found I liked the images better on Weather Flow’s live tile, but I was missing the chance of rain percentage. I figured I would just go into Amazing Wehater HD’s app to get that additional information.
Unfortunately, I have found that the live tile for Weather Flow doesn’t seem to show the correct temperature very often. For example, I just looked at my phone and I still have both live tiles going, updating every hour. The time on my phone is 12:32 and Weather Flow’s live tile shows it was updated at 12:28 with a temperature of 78 degrees. Amazing Weather HD’s tile showed 70 degrees. I figured that Amazing Weather just hasn’t updated the live tile yet, but that is a huge difference. When the live tile flips on Amazing Weather, I see that it just updated about 10 minutes ago. So I open up Weather Flow and after it refreshes it shows the temperature at 69 degrees! How can this be when the live tile just updated 4 minutes ago showing a temperature of 78 degrees?
This has happened repeatedly over the past few days and I am not sure why. I don’t know if others are just not noticing this or if there is some issue with the app. I have deleted the app and reinstalled it but that did not fix it.
Weather Underground's website showed a temperature of 69.5.
I am surprised this highly rated weather app is acting this way. Anyone have ideas?
