Working Time Pro - keep track of work hours
Arshini Preetish
I agree with Kenvin, Because I've heard a nice feedback of this application!
I'm using two different time tracking application and I can not imagine using it for my task lists. I think I need a cloud-based application which has at least a permanent window with the task list which is updated directly if something changes. Adding a task and then having to type task is to display the changed list seems quite complicated for me with that two applications. One of my friends suggested to use Replicon Software to solve this critical problem. And also gave this link to check - Online Time Recording Software | Employee Time Recording Systems | Online Time Recorder Software | Replicon
Does anyone know about this application, Any suggestions? Can I use this software on my Macs so that I can properly bill time spent on my typical projects?
babukapyar
