1. L3vi's Avatar
    Anyone experiencing massive battery drain with background tasks enabled? I'm using a Lumia 920.
    12-04-2013 02:27 PM
  2. BIGPADDY's Avatar
    Does this happen only with 6Snap in the background if so block it on setting then background task.
    01-01-2014 09:43 AM
  3. theroyboy44's Avatar
    I don't know about background but when using the app I have MASSIVE battery drain. Same goes with Rudy's newest app 6tindr!
    01-16-2014 10:33 AM
  4. theroyboy44's Avatar
    Does your battery drain only happen when u use the app or just when getting notifications a live tile updates?
    01-16-2014 10:34 AM
  5. L3vi's Avatar
    It seems to occur only after I open the app for the first time after charging my phone. After I open it the battery will drain rather quickly.
    04-13-2014 09:48 AM
  6. yeewiz's Avatar
    apparently, you are not alone. see this thread. I was trying to help this guy but to no avail. I would not have thought one app which did was always turned off after use, with no background task enabled, would be a massive battery killer. He too was using a 920::
    http://forums.windowscentral.com/nok...tery-life.html
    04-13-2014 12:25 PM
  1. Replies: 14
    Last Post: 01-24-2014, 08:57 AM
  2. here drive + bluetooth drains battery badly
    By flyedf in forum Windows Phones
    Last Post: 12-11-2013, 03:25 PM
  3. battery dead over night
    By haree in forum Windows Central Archive
    Last Post: 12-06-2013, 12:36 AM
  4. Replies: 2
    Last Post: 12-05-2013, 06:24 AM
  5. Replies: 7
    Last Post: 12-02-2013, 05:37 AM
