Sysapp Pusher not working, Please help
Lance_WPCentral
1,451
Hi guys, I noticed that SysApp pusher ain't working properly on my phone. I added all the apps on my phone to the MyApps section. Now in the MyApps section, Sysapp Pusher is there by default under the Amaze Pictures Inc tab. In the settings tab I have enabled check MyApp for updates and check MyApps in background. Some hours ago Sysapp Pusher was updated and a new version was availlable at the store but Sysapp Pusher didn't detect it. I opened SysApp Pusher and then manually hit check and the it detected 1 update.
My internet was on all the time. I'm not sure my its not checking automatically. have I missed out on something ?
Is the app blocked in background task , yes sysappusher is added by default in my apps category and you can not remove it , it got a new update adding bing and network speed test under Microsoft section
I'm not very sure if it was blocked in backgroud task. I hadn't gone and blocked it specifically, maybe the OS might have done it.
Another thing is after I updated the app from within SysApp Pusher, the count didn't disappear from the live tile. I had to go and manually set the app as already updated and then the count disappeared. Does it work that way or automatically for you guys ?
yes this is normal , one have to set the app as updated it will not set the app as updated automatically due to limited resources and API. but once you get an update for sysapppusher you can set the app as updated , once the app is updated you have to re-check the app for update and it will remove the sysappusher tile count
Himanshu, I guess your right. Looks like it was removed from background task by the OS. Now its showing the count on the live tile for Evernote as it received an update. Thanks a lot mate.
drgrhodes
