1. Kulsman's Avatar
    Is this possible? I am trying to limit the use of the physical button.
    04-22-2014 10:43 PM
  2. anon(7900571)'s Avatar
    04-22-2014 10:47 PM
  3. Kulsman's Avatar
    I was hopping to find a way to access the advance volume control panel without pressing the button
    04-22-2014 11:00 PM
  4. anon(7900571)'s Avatar
    advanced ? you don't have press volume button after installing the app , just pin the app on your start sreen and open it , from there you can slide to change the volume of your phone
    04-22-2014 11:11 PM
  5. Windowlino's Avatar
    Does this app still work with Windows 8.1? As Kulsman says he is looking to access the advanced control. So I guess he uses Win 8.1.
    04-23-2014 08:09 AM
  6. Kulsman's Avatar
    I am running windows phone 8.1. This app does not have advanced audio control capabilities
    04-23-2014 10:43 AM
  1. Replies: 6
    Last Post: 04-23-2014, 12:11 AM
  2. Are you supposed to see spinning gears on the 2nd Update??
    By WINDOW LOVIN in forum Other Operating Systems
    Last Post: 04-22-2014, 11:59 PM
  3. How do I force the Store to update my apps?
    By Himanshu Chowdhary in forum Other Operating Systems
    Last Post: 04-22-2014, 10:06 PM
  4. Volume control when headphones plugged in
    By EchoOne30 in forum Other Operating Systems
    Last Post: 04-22-2014, 09:38 PM
