Hi all,
Recently been using the Nokia Reading app to read eBooks and have found it drains my battery more than any other app I've ever used, even when I disable background usage. It also causes my phone (Lumia 1520 running DP 8.1 Update 1) to heat up incredibly to the point where it could literally burn my finger!
Have other experienced battery drainage and/or overheating while using this app?
