1. fredd's Avatar
    I bought the swann security system a couple of weeks ago. Does anyone know how I can see the cameras on my windows phone running DP 8.1. The swannview app doesnt work at all or maybe there is another way to see them. Any suggestions
    09-17-2014 10:20 AM
  2. fredd's Avatar
    Anyone???
    09-17-2014 04:36 PM
  3. Danjp's Avatar
    I don't have experience with Swann security systems, but you don't have specifics for your problem so its likely anyone will be able to help you with your vague information. Did you put in the ip address of the cameras? Have you had success setting it up on another device (android. IOS)?
    09-17-2014 04:54 PM
  4. fredd's Avatar
    Yes Ive put in the ip address Ive tried just about everything. The swannview app I believe is for windows phone 7 I was hoping maybe someone knew another way of seeing my cameras or maybe this thread would get someone to update the app. My wife had no trouble getting it setup on her Iphone.
    09-18-2014 09:03 AM
  5. fredd's Avatar
    Ok since nobody knows who would i talk to then. does anyone know how i might get an answer.
    09-19-2014 04:41 PM
  6. YoDaMic's Avatar
    I've got mine working flawlessly. Try using mobile port 9000 in the device setup. I remember I was having problems and this worked.
    Guytronic likes this.
    09-19-2014 05:28 PM
  7. fredd's Avatar
    Could you take a screen shot of the screen setup
    09-24-2014 12:05 PM
  8. YoDaMic's Avatar
    I have two setups, one for my local home network and one using Swann's DDNS service for when away from home. I've also included a bonus pic of the oil spots in my driveway. Hope this helps.
    09-24-2014 04:28 PM
  9. Andrew Tolson's Avatar
    Ive got the same problem with my windows phone and ive tried entering 9000 as suggested and nothing happens it just states connecting to server all the time
    12-17-2014 12:04 PM
  10. dsimages's Avatar
    You will need to port forward your router. Port 9000
    12-17-2014 10:42 PM
  11. dsimages's Avatar
    I use swannview every day.
    12-17-2014 10:42 PM
  1. Needs wifi to download games even though less than 100MB
    By Nithin Vs in forum Windows Central Archive
    Last Post: 10-24-2014, 10:20 PM
  2. Terraria Help: Can't Even Beat Tutorial
    By coip in forum General Phone Discussion
    Last Post: 09-25-2014, 06:01 PM
  3. Age of Empires: Castle Siege with Xbox LIVE now available for Windows Phone, Tablet, and PC
    Last Post: 09-19-2014, 12:08 PM
  4. Picture with Date and Time
    By bryanibuan in forum General Phone Discussion
    Last Post: 09-17-2014, 09:10 AM
  5. Turn your images into comic strips with the Windows Phone editor PhotoMic
    Last Post: 09-17-2014, 08:42 AM
