Surface Duo is on salefor over 50% off!
  1. floridarandy's Avatar
    Picked up a couple of these on fleabay today without cord and ac adapter. anyone have an idea of what ac adapter/cable this unit requires?
    Thanks
    02-20-2015 01:57 PM
  2. worldspy99's Avatar
    Unfortunately these are hard to find as they are specific to the Nokia wireless charging units...if I come across something I will let you know. Fleabay is probably your best bet...sometimes stuff pops up over at A4C as well.
    02-20-2015 02:00 PM
  3. Harrie-S's Avatar
    Below info is on my 910 adapter
    Model AC-301E salcomp
    Output DC 12V, 0.75A
    Input AC 100-240V , 50-60 hz, 0.3A
    http://headlane-parts.co.uk/Nokia_AC..._White_0675638
    http://www.a4c.com/product/nokia-ac-...hite-bulk.html
    Nokia Wireless Charging Stand - Microsoft - Global
    RumoredNow likes this.
    02-20-2015 02:10 PM
  4. RumoredNow's Avatar
    Great set of links...
    Harrie-S likes this.
    03-25-2015 02:52 PM
  5. RumoredNow's Avatar
    I ended up getting 2 of these.
    http://www.amazon.com/gp/product/B00...pUvbUpU3039084
    Seems impossible to get the AC-301 power supply and the CA-211 power cord in the same market. If you look down the page you'll see the Upbright replacement for CA-211 cord is only $1.45 less than the complete unit.
    Having fiddle farted around with power supplies and cords for a pair of "Orb" style chargers I picked up cheap; I've learned a bit. These Upbrights have the correct 12V output if they aren't labeled wrong on the site. Mismatch on that is a PITA.
    Will advise further when they arrive.
    03-26-2015 10:51 AM
  6. RumoredNow's Avatar
    So it turns out I got the two DT-910's from floridarandy as part of a 928 bundle.
    The AC adapters I got from Upbright (linked above) do the trick nicely. They just came in and I tested one. Shows charge rate 17.85% and holds a good connection even through a TPU case on my 1520.3..
    The story has now come full circle.
    03-30-2015 09:06 PM
  1. Interesting accessories for Stream 7.
    By chovan in forum Other Brands
    Last Post: 04-01-2016, 04:45 PM
  2. Replies: 2
    Last Post: 02-21-2015, 02:30 PM
  3. What is the best camera for WindowsPhone 8.1?
    Last Post: 02-20-2015, 09:46 PM
  4. Replies: 5
    Last Post: 02-20-2015, 01:51 PM
  5. Work aound for "memory unformatted" problem on Xbox 360.
    By chovan in forum Gaming Discussion
    Last Post: 02-20-2015, 01:33 PM
