1. arjan wolthuis's Avatar
    today i upgraded my CPU, (Athlon X2 to X3), the new cpu has 3 cores clocked at 3,40 Ghz, but my computer sounds like a jet engine, 4000 RPM cpu fan have beenn mearsurd. normal it lies around 1300 Rpm. The core tempatures are normal. new paste have been applied. Why is my fan have 4000 RPM
    06-11-2015 06:43 PM
  2. Guytronic's Avatar
    Is the fan plugged onto the correct board connector?
    06-11-2015 07:42 PM
  3. djeire84's Avatar
    Is the fan properly secured to the case/motherboard? Is the fan being restricted by cabling? Is the tower on a level surface? Do you have enough thermal compound on the CPU?
    06-11-2015 07:45 PM
  4. arjan wolthuis's Avatar
    The fan was not good plugged in, i run a stress test and the fan stayed around 2500 RPM
    Guytronic and djeire84 like this.
    06-12-2015 10:55 AM
  1. Why is there no Miracast support?
    By Miffywiffy in forum Windows Phones
    Last Post: 06-13-2015, 12:16 PM
  2. Replies: 4
    Last Post: 06-11-2015, 09:51 PM
  3. Replies: 2
    Last Post: 06-11-2015, 06:32 PM
  4. Oculus Touch is the finger-based controller prototype for the Oculus Rift
    Last Post: 06-11-2015, 02:11 PM
  5. Microsoft is inviting some Windows Insiders to attend E3, Gamescom and other events
    Last Post: 06-11-2015, 10:00 AM
