1. yanpaulo's Avatar
    Hi.
    I've searched everywhere, but there isn't any concrete information on Lumia's real support for faster Micro SD card types.
    In the phone specification pages, I only see that it's compatible with "Micro SD", but that is too vague.
    I know that any card that I put in my phone will work, but I don't know which card types will really make a difference for anything.
    Basically, I want to know which Micro SD card types a Lumia phone can really handle (where handle = use its full speed) (by card types I mean class 6, class 10, UHS-I, and so on).
    By the way, I own a Lumia 640 phone.
    07-24-2015 12:57 PM
  2. OldMillXxX's Avatar
    Ever get further on this? I, too would like to know if I'm throwing money out the window with a class 10, if all I truly need is a class 4.
    yanpaulo likes this.
    08-06-2015 10:26 AM
  3. yanpaulo's Avatar
    Just bought a class 10 UHS-1 card.
    Tested it in my computer (manually copying big files).
    Its write speed was more than 2x faster than that of my old class 4's.
    In the other hand, read speeds was identical, so I guess I threw some somey out of the window. :p
    Not that much, though, since I did need a 32GB card anyway, and the UHS-1 class 10 was just about 15 bucks more expensive.
    08-10-2015 09:07 AM
  1. Temperamental Tap to Wake on the Lumia 730
    By greedo_greedy in forum Windows Phones
    Last Post: 08-09-2015, 08:26 PM
  2. Finding my windows phone with out a serial number?
    By Sydney Lambert in forum Ask a Question
    Last Post: 07-24-2015, 04:53 PM
  3. Replies: 1
    Last Post: 07-24-2015, 12:54 PM
  4. Why is my Nokia Lumia 1020 in a reboot loop from a hard reset?
    By Windows Central Question in forum Windows Phones
    Last Post: 07-24-2015, 12:49 PM
