Can I get some help with a problem running Money 2001 with Windows 10?
Problem running Money 2001 with Windows 10
I have noted various comments re necessity to amend change the Reg Edit for IE.
I have located the item in reg edit but was not able to change it either by highlighting and over typing or deleting.
How exactly is an entry in reg edit altered.
sixsigma
