1. wishdamume's Avatar
    I've been skimming the forums, but I haven't found any definitive answer. I love the NFC of the Nokia CR-200, but that I've heard isn't big enough nor consistent. Is there any reliable wireless car charging holder for the 950, with or without NFC?
    01-04-2016 03:11 PM
  2. Josh Harman's Avatar
    I'm looking for the same, or at least a cradle without charging that fits the 950.
    01-16-2016 02:02 PM
  3. midnightfrolic's Avatar
    Picked this one up in gray today. There are several colors to choose from. Works well enough so far. The bottom bracket is removal. Package comes with an additional bottom bracket that has a cutout for WIRED phone charging cable.
    TYLT V Wireless Charging Vehicle Mount Green VUCARG-T - Best Buy
    01-26-2016 07:06 PM
  4. Josh Harman's Avatar
    Click image for larger version.
    Do you have a 950, and does it fit in the charger without pressing the buttons?
    01-27-2016 10:57 PM
  5. midnightfrolic's Avatar
    I have the 950XL. With a rugged case. It barely fits. Charges fine even with the case. Gets barely warm. Happy camper so far in the half day I've had it. It does not press the buttons. Even without a case. You can adjust the height because the bottom brace/bracket is adjustable.
    EDIT: Took it for several hr drive. It got kinda hot. Did not charge much. Possibly due to me using Groove. Gonna try using a Usb C cable to charge to test out.
    EDIT 2: after more usage of the TYLT qi car chafer, it charges ~4% every 10 minutes. Which would equate to ~3.5 hrs for a full charge from zero. Which is about average with other chargers. The car adapter itself has a Usb port to charge another device via wired Usb cable.
    01-28-2016 11:25 AM
  6. Philip Colmer's Avatar
    Having bought the Tylt VU last year for use with my 830, I've had to return it after the "sticky" pad that attaches the charger to the car lost its stickiness. The UK distributor is saying that this device is now discontinued so I'm now on the hunt for a new Qi car charger ...
    02-05-2016 10:50 AM
  7. slyronit's Avatar
    Any updates? Is the CR-201 still available? My CR-201 lost its stickiness after 3 years of great service. I would still get the CR-201 again and saw off the bottom (like I did for the last one)
    04-26-2016 01:16 AM
  8. slyronit's Avatar
    I ended up getting a CR-200/201 (Wouldn't know which, till it is delivered) from China, off eBay. I know I have to cut the lip off again, but I couldn't find a viable alternative.
    04-27-2016 07:38 AM
  1. Why *haven't* you bought a Lumia 950?
    By MarkAllett in forum Windows Phones
    Last Post: 12-27-2016, 10:17 AM
  2. 950 not on ATT corporate website!!
    By cheesemoo in forum Windows Phones
    Last Post: 01-27-2016, 09:31 PM
  3. Suggestions for a tablet?
    By Windows Central Question in forum Windows 10
    Last Post: 01-04-2016, 03:50 PM
  4. Web filter apps for Windows 10 Mobile?
    Last Post: 01-04-2016, 02:29 PM
  5. 950 xl still not receiving any update
    By Michael Simonov in forum Windows Phones
    Last Post: 01-04-2016, 01:57 PM
