Settings and Info - Use 3G to change settings
mark233
1,118
I've got an 830 RM-985 with T-mobile SIM and my phone has this setting showing. I don't know what it does tho. I suppose you could tick the switch to 'On' and find out .. so --- go ahead and switch it to 'On' and report back. :smile:
Alain_A
988
why don't you?
that is what I thought a T-Mobile thing..
maybe it is only for wifi calling settings
mark233
1,118
Well --- maybe it's for WiFi calling even tho this 830 doesn't have it ....
... ok I switched the setting to 'On' --- only thing I can see is I no longer am connected to T-Mobile LTE .... now on T-Mobile 3G
Alain_A
988
you guys restarted the phone?
it says to change some settings. Have you look at the sim setting after?
unless it is just a switch to toggle between LTE and 3 g if you are inside of a building or out of LTE area
powerupgo
