Is there any way to charge the HP Stream 7 when using an OTG Cable?
  • Start date
I have a OTG cable with a usb micro pass through with a USB Female input.
I can definitley plug in the mouse and use that, but the micro usb pass through seems to NEVER pass through power.
It's a cheap Chinese cable.
So I'm wondering if anyone has ever successfully charged the tablet AND use peripherals at the same time?
nordnord
7
Look for the post where they discuss periphs that sometimes work with the Stream.
I bought a few and found one that seems (I'm still studying it) to work well. It is the nekmit power plug with 2 regular sized USB connectors and a Y split 2 usb cables on one end and a mini usb connector on the other end. The cable is fairly long. I totally ditched the cheap charger that HP provided... it is not strong enough to charge anything other than the tablet itself. The second you try to put in a hub (I use the little belkin 4 port), you start losing battery power.
Too early to say for sure, but would be curious if anyone else has tried this. Right now, I have an external USB stick for backup of data plugged in along with a USB 2 flexible keyboard and a usb gigaware portable mouse.
Groover1971
66
I don't have the Stream 7 anymore but when I did, I watched a YouTube video and showed what to get. I bought the cables and hub and it actually worked. The problem was that it was a slower charge and the charging indication on the battery icon wouldn't show that it was charging, even though the charge would slowly increase. Initially, I had a USB mouse and keyboard connected to the hub and used Miracast to project to my TV. It worked great but I didn't want to have all of those cables laying around all of the time. You may have to switch the power (red) and data (black) connectors on the Startech Y-cable. In the video, he shows that it is charging using an amp meter since the indication doesn't show. He also didn't use a USB hub because he was using Bluetooth. The link for the video is below.
https://youtu.be/dpcrkqjZfl8
kuyhaa
